Sony Vaio Fit 13A Screen Replacement
  1. Sony Vaio Fit 13A Screen Replacement, Screen: step 1, image 1 of 3 Sony Vaio Fit 13A Screen Replacement, Screen: step 1, image 2 of 3 Sony Vaio Fit 13A Screen Replacement, Screen: step 1, image 3 of 3
    • Unlock the screen and lift the corner. Carefully turn it over until it faces away from the keyboard. This is the same procedure as turning the screen over to use the computer in the fashion of a tablet.
  2. Sony Vaio Fit 13A Screen Replacement, Unscrew the Screen: step 2, image 1 of 2 Sony Vaio Fit 13A Screen Replacement, Unscrew the Screen: step 2, image 2 of 2
    • Locate and remove all ten 1 mm Phillips #0 screws.
  3. Sony Vaio Fit 13A Screen Replacement, Remove the Screen: step 3, image 1 of 2 Sony Vaio Fit 13A Screen Replacement, Remove the Screen: step 3, image 2 of 2
    • Use the Metal Spudger Set to carefully separate screen from backing. Be sure to keep the grey panel flush with the screen front.
  4. Sony Vaio Fit 13A Screen Replacement, Remove this Connection: step 4, image 1 of 2 Sony Vaio Fit 13A Screen Replacement, Remove this Connection: step 4, image 2 of 2
    • Remove the 1mm screw that is connecting the screen and the device.
    • Use the Philips Head #0 screwdriver to remove the screw.
  5. Sony Vaio Fit 13A Screen Replacement, Remove Strip: step 5, image 1 of 3 Sony Vaio Fit 13A Screen Replacement, Remove Strip: step 5, image 2 of 3 Sony Vaio Fit 13A Screen Replacement, Remove Strip: step 5, image 3 of 3
    • Use tweezers to carefully separate the two connections of the strip from screen back panel.
  6. Sony Vaio Fit 13A Screen Replacement, Screen is Now Removed: step 6, image 1 of 2 Sony Vaio Fit 13A Screen Replacement, Screen is Now Removed: step 6, image 2 of 2
    • Replace with the new screen.
Marii
658 Reputation
3 Guides authored
Cal Poly, Team 21-19, Maness Winter 2015 Member of Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 6,938
