Introduction
Before start the procedure, make a system backup (I use ToDo Backup Free).
Some pictures were found in:
http://henjinkutsu.com/text/pc/svd1121aj...
Tools
Parts
No parts specified.
Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
Remove the screws (circled in red) and remove the battery.
When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
24 other people completed this guide.
12 Comments
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Thanks so much!! It worked for me though somehow my internal speakers and headphones are gone (After re-installing custom windows 8.1) Could the yellow flexible flat cable be in any way connected to the sound card? I would appreciate any help
Try this: Go to Control Panel>System and Security>System and to the left, click on Advanced System Settings. Worked for me:
tenebro -
J'ai un vaio duo 11 à vendre
Intel Core i5-3337U 1.8GHz / 8Go de Ram / Windows 10 Argent En plus de l'ordinateur, une carte mémoire 256Go et une pochette de transport en cuir.
Le prix neuf de l'ordinateur était 1600€
Hi, where can I buy a replacement SSD to suit my SONY VAIO SVD112A1SW?
Hi, what do you do with old SSD?
