Sony SRS-BTX500 Battery Replacement
  1. Sony SRS-BTX500 Battery Replacement, Battery: step 1, image 1 of 3 Sony SRS-BTX500 Battery Replacement, Battery: step 1, image 2 of 3 Sony SRS-BTX500 Battery Replacement, Battery: step 1, image 3 of 3
    • Locate the four rubber grips on the bottom of the speaker. Use the plastic opening tool to remove the grips, exposing the underlying screws.
  2. Sony SRS-BTX500 Battery Replacement: step 2, image 1 of 2 Sony SRS-BTX500 Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four 5mm screws that were underneath the four rubber grips.
  3. Sony SRS-BTX500 Battery Replacement: step 3, image 1 of 3 Sony SRS-BTX500 Battery Replacement: step 3, image 2 of 3 Sony SRS-BTX500 Battery Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to run along the outside edges of the speaker. Pry along the seams until you can remove the side panel of the speaker, exposing the battery.
  4. Sony SRS-BTX500 Battery Replacement: step 4, image 1 of 3 Sony SRS-BTX500 Battery Replacement: step 4, image 2 of 3 Sony SRS-BTX500 Battery Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to remove the battery from casing.
    • Unclasp the battery from the speaker. Remove and replace.
4 other people completed this guide.
Fadi Mohamed
191 Reputation
1 Guide authored
11 Comments
Thanks for the great tutorial and all the help, Finally got to the battery YAY.. now if only I could find a way to fix my other one, it's little brother, The BTX300 It's a little different than the 500 to get into Although the battery is extremely easy, but I don't know where to start after that, even with the side kick stand I can't figure out how to get into the darn thing,
I need to fix / replace the yellow plastic part/ CONNECTION on the rear of the speaker for the charging port, unfortunately the yellow plastic piece broke after a fall when it was plugged in, It still worked until it lost the charge, so I can't charge it at all, just leaving the 2 pins sticking up inside the hole there,
If there's any kind of idea how to do this and replace the part or even if I had to a "duck tape & binder twine" solution if I could get it to just charge, they are great Bluetooth speakers
IF ANYONE HAS ANY IDEAS PLEASE PLEASE LET ME KNOW ☺️I Would be so great full,
Kindest Regards
Luckystyx
Lucky Styx - Reply
Where can I buy the battery to replace it?
Andrei - Reply
Try with this part#: X-2587-179-1, this is the battery used for other countries except US, because these speakers are not for repair, so I doubt that an authorized Sony service center can fix it, but you can place the other in encompass parts, even they will say that belongs to SRSBTX300 but apparently do match, check the specs, 7.4V 13.7Wh (14WHh) 1850mAh with them, the average cost is $130USD, there is another battery in the market with same specs but believe me, is not going to work due to T terminal vs C terminal of the Sony one. good luck attn: Mr. L.
Mr. L. -
Andrei, try contacting Sony to determine where you can buy a new battery. They would know for sure and I don't want to tell you the wrong thing.
Luckystyx, wish we could help you out more but we only know how to fix the 500. Sorry about that!
Sydney Legeer - Reply
I am desperate to source a battery, too. If anyone finds one, please post where you got it! I like this speaker a lot!
bunkywise - Reply
Oh, and Sony says the battery is only replaceable by an authorized Sony representative and I sure don't have one of those handy!
bunkywise - Reply
See my response to Andrei, regards
Mr. L. -
The batteries are just 2x 18650s if your inclined to replace them yourself.
eastyamg - Reply
After all this time I am also looking for a replacement battery for the 500 model. Has anyone come up with it yet?
Phil Bruni - Reply
Also looking for battery
Michael Shutlock - Reply
Bonjours pour une enceinte sony srs btx500 je dois prendre qu'elle batterie es que vous avez un lien pour m'aider merci
Christophe Badoil - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 6,745
