You're viewing a previously published version of this guide.  View latest version
Older Newer
  1. Unscrew the screws on the top of the radio.
    • Unscrew the screws on the top of the radio.
  2. Open the CD and cassette doors and remove the screws in the compartments. To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Remove the top of the radio enough to access the wires for removal.
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Remove all of the wires that are connected to both the circuit board and the underside of  the top of the radio by pulling them where they are connected
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
Ian Nussman
881 Reputation
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 64
