Sony Handycam HDR­-CX220 Lens Replacement
  1. Sony Handycam HDR­-CX220 Lens Replacement, Battery: step 1, image 1 of 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Lens Replacement: step 2, image 1 of 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: step 3, image 1 of 3 Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: step 3, image 2 of 3 Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: step 3, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Lens Replacement: step 4, image 1 of 3 Sony Handycam HDR­-CX220 Lens Replacement: step 4, image 2 of 3 Sony Handycam HDR­-CX220 Lens Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Lens Replacement: step 5, image 1 of 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Lens Replacement, Lens: step 6, image 1 of 3 Sony Handycam HDR­-CX220 Lens Replacement, Lens: step 6, image 2 of 3 Sony Handycam HDR­-CX220 Lens Replacement, Lens: step 6, image 3 of 3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Lens Replacement: step 7, image 1 of 1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Lens Replacement: step 8, image 1 of 1
    • Remove the lens and clean it if needed.
Keven
811 Reputation
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 715
