Sony H.ear On 2 Battery Replacement
  1. Sony H.ear On 2 Battery Replacement, Battery: step 1, image 1 of 2 Sony H.ear On 2 Battery Replacement, Battery: step 1, image 2 of 2
    • Start by inserting the iFixit plastic opening tool into the crease between the hard plastic and the ear cup on the right side of the headphones. Then you should gently apply pressure until it separates.
    • You may need to repeat the process on the back using your hands or the iFixit plastic opening tool until it separates completely.
    • This may take a considerable amount of pressure but do not force it.
  2. Sony H.ear On 2 Battery Replacement: step 2, image 1 of 2 Sony H.ear On 2 Battery Replacement: step 2, image 2 of 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
    • There is a ribbon cable connecting the plastic cover to the battery housing on the headphones. Be wary not to damage this cable during disassembly by lifting the cap forcefully.
  3. Sony H.ear On 2 Battery Replacement: step 3, image 1 of 2 Sony H.ear On 2 Battery Replacement: step 3, image 2 of 2
    • Using the iFixit opening tools, gently separate the battery from the housing
    • The ribbon cable connecting the plastic cover to the battery housing is short, so make sure to move the plastic cover out of the way safely
    • The battery is adhered to the housing with epoxy. When removing the battery be aware that separation may require a bit of force.
    • Be careful not to damage the battery contacts during removal.
Braden Michelson
378 Reputation
1 Guide authored
Cal Poly, Team S9-G11, Maness Spring 2019 Member of Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Members
16 Guides authored
Past 24 Hours: 11
Past 7 Days: 50
Past 30 Days: 192
All Time: 11,928
