Repairing Sony Cybershot DSC-W5 Speaker
  1. Repairing Sony Cybershot DSC-W5 Speaker, Back Cover: step 1, image 1 of 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Repairing Sony Cybershot DSC-W5 Speaker: step 2, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 2, image 2 of 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Repairing Sony Cybershot DSC-W5 Speaker: step 3, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 3, image 2 of 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Repairing Sony Cybershot DSC-W5 Speaker, LCD Screen: step 4, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker, LCD Screen: step 4, image 2 of 2
    • Remove the two screws holding the circuit board down.
  5. Repairing Sony Cybershot DSC-W5 Speaker: step 5, image 1 of 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Repairing Sony Cybershot DSC-W5 Speaker: step 6, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 6, image 2 of 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 1 of 3 Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 2 of 3 Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 3 of 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Repairing Sony Cybershot DSC-W5 Speaker, Speaker: step 8, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker, Speaker: step 8, image 2 of 2
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Repairing Sony Cybershot DSC-W5 Speaker: step 9, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 9, image 2 of 2
    • Now remove the plastic plate that covers the motherboard.
  10. Repairing Sony Cybershot DSC-W5 Speaker: step 10, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 10, image 2 of 2
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Repairing Sony Cybershot DSC-W5 Speaker: step 11, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 11, image 2 of 2
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
  12. Repairing Sony Cybershot DSC-W5 Speaker: step 12, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 12, image 2 of 2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
Thomas
133 Reputation
6 Guides authored
Cal Poly, Team 15-50, Garner Spring 2010 Member of Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,603
