Introduction
This guide will aid you in the process of replacing the battery.
Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
Rosario
24 Reputation
3 Guides authored
Cal Poly, Team 7-35, Maness Spring 2012 Member of Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 451
