Sony Alpha DSLR- A850 Focusing Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
109
All Time:
1,600
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 3 of 3
      • Push in the button next to the lens.
      • While holding the button twist the lens counter-clockwise.
      • Pull up and remove lens from camera.
      Ask FixBot
    2. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 3 of 3
      • Inside toward the top you will find a small slit in the plastic piece.
      • Insert a flat head screw driver into the slit and pull down to access the focusing screen.
      Ask FixBot
    3. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers grab the focusing screen on the side by the two tabs that are on it.
      • Do not grab the focusing screen in the middle as this will damage it.
      • Pull out and remove focusing screen from camera.
      Ask FixBot
    4. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 3 of 3
      • When inserting new screen make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
      • Angle the focusing screen to make installation easier.
      • Lay the new focusing screen into the plastic tray.
      • It does not snap into place.
      Ask FixBot
    5. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 5, image 1 of 2 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 5, image 2 of 2
      • Insert screw driver into the slit and push up to close.
      • You can also use your thumb, if you are careful not to touch the screen as this could leave a smudge on it.
      • You will hear a click when the plastic tray is back in place.
      Ask FixBot
    6. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 6, image 1 of 2 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 6, image 2 of 2
      • When re-installing the lens line up the orange dots that are one both lens and camera.
      • Fit lens into place and turn clockwise to secure it back to camera.
      Ask FixBot
You have now completed a focusing screen replacement.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 109
All Time: 1,600
