Sony Alpha A3000 shutter button Replacement
  1. Sony Alpha A3000 shutter button Replacement, Rear Case: step 1, image 1 of 3 Sony Alpha A3000 shutter button Replacement, Rear Case: step 1, image 2 of 3 Sony Alpha A3000 shutter button Replacement, Rear Case: step 1, image 3 of 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 shutter button Replacement: step 2, image 1 of 2 Sony Alpha A3000 shutter button Replacement: step 2, image 2 of 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 shutter button Replacement: step 3, image 1 of 2 Sony Alpha A3000 shutter button Replacement: step 3, image 2 of 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 shutter button Replacement, Motherboard: step 4, image 1 of 2 Sony Alpha A3000 shutter button Replacement, Motherboard: step 4, image 2 of 2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 shutter button Replacement: step 5, image 1 of 2 Sony Alpha A3000 shutter button Replacement: step 5, image 2 of 2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 shutter button Replacement: step 6, image 1 of 2 Sony Alpha A3000 shutter button Replacement: step 6, image 2 of 2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 shutter button Replacement: step 7, image 1 of 1
    • Remove the metal casing.
  8. Sony Alpha A3000 shutter button Replacement: step 8, image 1 of 1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 shutter button Replacement: step 9, image 1 of 2 Sony Alpha A3000 shutter button Replacement: step 9, image 2 of 2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 shutter button Replacement: step 10, image 1 of 1
    • Finally remove the motherboard from the casing.
  11. Sony Alpha A3000 shutter button Replacement, ...: step 11, image 1 of 1
    • shutter button placement...
  12. Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: step 12, image 1 of 2 Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: step 12, image 2 of 2
    • Remove two screws holding plastic/metal frame.
  13. Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: step 13, image 1 of 2 Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: step 13, image 2 of 2
    • Holding the battery door gently lift the frame up .
  14. Sony Alpha A3000 shutter button Replacement, Capacitor module: step 14, image 1 of 2 Sony Alpha A3000 shutter button Replacement, Capacitor module: step 14, image 2 of 2
    • Pull out the capacitor and move the capacitor board (flexible) to the left to clear the way for future steps.
  15. Sony Alpha A3000 shutter button Replacement, Remove buttons module: step 15, image 1 of 3 Sony Alpha A3000 shutter button Replacement, Remove buttons module: step 15, image 2 of 3 Sony Alpha A3000 shutter button Replacement, Remove buttons module: step 15, image 3 of 3
    • Remove two screws mounting plastic buttons module.
    • Remove the module.
  16. Sony Alpha A3000 shutter button Replacement, Soldering!: step 16, image 1 of 3 Sony Alpha A3000 shutter button Replacement, Soldering!: step 16, image 2 of 3 Sony Alpha A3000 shutter button Replacement, Soldering!: step 16, image 3 of 3
    • Replace the ALPS SKSDPCE010 microswitch. Look out for the correct allignment and orientation (first pin marked with a dot).
Andrzej Majchrzak
131 Reputation
1 Guide authored
3 Comments
Excellent article, I would like to know what should be done to replace or repair the mode selector of the camera, (Dial mode) I appreciate this great contribution. Greetings.
Edgar Delgado - Reply
Mode selector switch is visible on 2 photos of buttons module PCB. Look for a switch with blue knob on 2nd Photo of step 16. I dont know the serial number or replacement.
Andrzej Majchrzak - Reply
Thank you so much for reply.
Edgar Delgado -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 2,501
