Sonos Five Midwoofer Replacement
  1. Sonos Five Midwoofer Replacement, Grill Removal: step 1, image 1 of 3 Sonos Five Midwoofer Replacement, Grill Removal: step 1, image 2 of 3 Sonos Five Midwoofer Replacement, Grill Removal: step 1, image 3 of 3
    • Use a thin guitar pick to carefully pry up on the grill
    • Be sure the pick is being wedged between the side of the casing and the rubber grill frame, and not the plastic mesh itself!
  2. Sonos Five Midwoofer Replacement, Grill Removal Continued: step 2, image 1 of 3 Sonos Five Midwoofer Replacement, Grill Removal Continued: step 2, image 2 of 3 Sonos Five Midwoofer Replacement, Grill Removal Continued: step 2, image 3 of 3
    • Continue freeing the grill
    • Make sure to note the circled posts when reinstalling to prevent damage
  3. Sonos Five Midwoofer Replacement, Left Midwoofer Removal: step 3, image 1 of 3 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: step 3, image 2 of 3 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: step 3, image 3 of 3
    • Remove the four T20 screws securing the driver to the front panel.
    • Be sure to align the speaker properly with it's alignment posts during reinstallation (third photo)
  4. Sonos Five Midwoofer Replacement, Disconnecting The Driver: step 4, image 1 of 3 Sonos Five Midwoofer Replacement, Disconnecting The Driver: step 4, image 2 of 3 Sonos Five Midwoofer Replacement, Disconnecting The Driver: step 4, image 3 of 3
    • The insulated terminal simply disconnects
    • The non insulated terminal has a tab that must be depressed to remove.
    • Remove the midwoofer from the unit
  5. Sonos Five Midwoofer Replacement, Center Midwoofer removal: step 5, image 1 of 3 Sonos Five Midwoofer Replacement, Center Midwoofer removal: step 5, image 2 of 3 Sonos Five Midwoofer Replacement, Center Midwoofer removal: step 5, image 3 of 3
    • Lift the midwoofer out of the cabinet slightly to disconnect the terminals
    • The center midwoofer driver wires are extremely short. Care must be taken to not strain the wires. This is a two handed operation of holding the driver while disconnecting the terminals
    • The insulated terminal simply slides off, but the non insulated terminal has a locking tab that must be depressed.
  6. Sonos Five Midwoofer Replacement, Right Midwoofer Removal: step 6, image 1 of 3 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: step 6, image 2 of 3 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: step 6, image 3 of 3
    • Lift the driver out of the cabinet.
    • The left noninsulated terminal has a locking tab that must be depressed. The right terminal simply pulls off
Nicholas Ouimet
3,620 Reputation
11 Guides authored
2 Guide Comments
Hola sabes donde podría comprar los parlantes tengo un somos five y están las tres bocinas reventadas
Ricardo.tranamil.h@gmail.com
Ricardo tranamil - Reply
Hola nesecito comprar las bocinas de repuestos por favor
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 51
All Time: 2,421
