Introduction
This guide will instruct a person on how to replace the carbonation tube line used in the delivery of CO2.
Locate the two prongs at the bottom of the button which releases the bottles (at the front of the machine).
Push both prongs down together; pull this part of the machine out towards you.
Press in the two gray oval shaped buttons found on either side.
Gently pull back on the cover until it releases from the device.
Release the buttons and pull the back completely off.
Place your hand under the carbonation button and pull up and away from you, towards the back of the machine.
Under the carbonation button, at the end of the slim black tube will be a white cap, turn the cap in a counter clock wise motion to remove.
Locate the second white cap, on the front of the machine. Reattach both white caps by turning them in a clockwise direction, ensuring they are on tight.
Line up the prongs on the front cover with those on the machine and gently push until in place.
8 other people completed this guide.
8 Comments
mine broke too. plastic nut split in half. probably from chill of CO2 expansion.
where to get replacement part?
I’m trying to find this nut and tube everywhere. any idea where we can purcase it? or the size and pitch of the nuts au tube?
that makes four of us— where’s the tubing available??
Sodastream refuses to sell parts. Maybe get a non working one on eBay for parts.
someone found it?
Giday Katie, nice work ive just carried out your instructions. im a tradie, and im wrapt by your skills demonstrated. easy to read and i didnt break anything. all the best
cheers
shayno
Someone made the part adapter.
unclipping from behind is a heck of a lot easier
Lake Country POKER - Reply
