SkullCandy INK'D 2 Audio Jack Replacement
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: step 1, image 1 of 2 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: step 1, image 2 of 2
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: step 2, image 1 of 1
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: step 3, image 1 of 1
    Tool used on this step:
    Heat Shrink Tubing Assortment
    $7.99
    Buy
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: step 4, image 1 of 1
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: step 5, image 1 of 1
    Digital Multimeter
    $19.99
    Buy
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: step 6, image 1 of 3 SkullCandy INK'D 2 Audio Jack Replacement: step 6, image 2 of 3 SkullCandy INK'D 2 Audio Jack Replacement: step 6, image 3 of 3
    Heat Gun
    $24.99
    Buy
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
119 Reputation
1 Guide authored
Cal Poly, Team S4-G1, Livingston Fall 2017 Member of Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Members
25 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 119
All Time: 15,459
