Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement
  1. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement, Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 1, image 1 of 2 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement, Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 1, image 2 of 2
    • To adjust the tension, spin the dial located above the needle.
    • The default setting is 5. A higher number increases thread tension, and a lower number decreases thread tension.
    • WARNING: Having the tension too high may cause the needle to snap.
    Ask FixBot
  2. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 2, image 1 of 2 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 2, image 2 of 2
    • To test the thread tension, take a scrap piece of fabric and sew a short line.
    • If the thread is getting bunched up leaving an incomplete line, the tension is likely too high. Proper tension will leave a straight, completed line.
    • Adjust thread tension as needed and retest until it is correct.
    Ask FixBot
  3. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 3, image 1 of 1
    • To replace a needle, begin by unscrewing the screw located to the right of the needle.
    • Rotate the screw away from you to loosen the screw.
    Ask FixBot
  4. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 4, image 1 of 1
    • Singer needles commonly come in small packs such as these.
    • There are different types of needles, but the most common needles are the 80/12 Universal Needles.
    • If you're sewing a heavy-weight fabric, you may choose a heavy duty needle to avoid snapping the needle.
    Ask FixBot
  5. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 5, image 1 of 1
    • Remove the needle. Replace the needle with a fresh needle.
    • Rotate the screw away from you to tighten the screw.
    • Make sure the you hold the needle in place when tightening the screw to ensure correct needle placement.
    Ask FixBot
  6. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 6, image 1 of 3 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 6, image 2 of 3 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 6, image 3 of 3
    • Another reason the sewing machine is not sewing properly might be due to a misaligned bobbin.
    • To check the bobbin, remove the front section of the sewing machine by firmly sliding the section to the left.
    • Open the hinge door towards you to reveal the bobbin.
    • Check to see if the bobbin is firmly in place. If the bobbin is loose, shift the bobbin to fit firmly in place.
    Ask FixBot
  7. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: step 7, image 1 of 1
    • This is how the bobbin should look.
    Ask FixBot
Finish Line
Emma Arntzen
145 Reputation
1 Guide authored
UC Davis, Team 1-2, Andersen Winter 2025 Member of UC Davis, Team 1-2, Andersen Winter 2025
UCD-ANDERSEN-W25S1G2
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 107
All Time: 1,128
