Introduction
The Shift 6m from 2018 is an easy-to-open phone that has a user-removable battery. It nearly reaches repairability perfection by prioritizing screen repair and shipping with a mini screwdriver in the box for disassembly.
Tools
Parts
No parts specified.
Exterior reference shots.
As on every Shiftphoneâs rear panel, we find a refreshing note at the bottom.
The back cover and battery are both user removable and easy to replaceâno tools required.
The back cover houses the NFC antenna.
With its 16.3Â Wh (4242Â mAh @ 3.85Â V) the Shiftphone's battery surpasses the iPhone Xs Max (12.08 Wh) and even the Galaxy S10 (13.09 Wh), but falls behind Huawei's Mate 20 X (19.1Â Wh).
The rear camera can be disconnected and removed right away.
Although the front-facing camera is connected on top of the motherboard, a small adhesive strip holds it to the back.
The power and volume button and fingerprint sensor connectors are inconveniently located on the back of the motherboard.
The last parts to come out of the mid-frame are:
The daughterboard with the interconnect and antenna cable connected underneath.
The fingerprint sensor and flash unit.
The power and volume buttons.
Surprisingly, the top and bottom antennas can be removed from the frame with the bottom part carrying the loudspeaker.
The Shift 6m earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
Battery and screen repairs are prioritized.
Only one type of screw head and length are used throughout the phone.
The manufacturer provides a few repair guides, and a screwdriver is shipped with the phone.
Most components are modular and can be replaced individually.
Some cables are quite short and components overlap, making repairs more complicated than necessary.
13 other people completed this guide.
4 Comments
Past 48 hour data download
View Statistical analysis
Would that work?
Where to buy replacement parts?
directly from shift. Screens and Batteries are directly purchasable from their website; other parts will be sent to you after evaluating the damage with an employee via mail or phone to rule out people buying the wrong spare part and throwing it away in the process.
