Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
I am not responsible for anything in this article.
  1. Remove - Back,microSD,battery,sim Remove black rubber screw covers on back of display. Remove 000 phillips screws (4) from top of display.
    • Remove - Back,microSD,battery,sim
    • Remove black rubber screw covers on back of display.
    • Remove 000 phillips screws (4) from top of display.
  2. Remove 3 small silver screws from battery area. Remove 2 Torx t-7's by MicroSD slot.
    • Remove 3 small silver screws from battery area.
    • Remove 2 Torx t-7's by MicroSD slot.
    • After screws are removed you can detach screen.
  3. Remove 4 additional 000 phillips screws from display. Using some heat,spudger,frce pry away the broken display from the frame. Use extreme caution the actual display is very fragile.
    • Remove 4 additional 000 phillips screws from display.
    • Using some heat,spudger,frce pry away the broken display from the frame.
    • Use extreme caution the actual display is very fragile.
  4. Remove connector for digitizer replace connector with new digitizer and rebuild. replace connector with new digitizer and rebuild.
    • Remove connector for digitizer
    • replace connector with new digitizer and rebuild.
  5. Reconnect to main motherboard. Reconnect to main motherboard. Reconnect to main motherboard.
    • Reconnect to main motherboard.
  6. reassemble. Enjoy the new display Enjoy the new display
    • reassemble.
    • Enjoy the new display
jckoniecki
51 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,257
