Shop the Holiday Gift Guide
Shark RV912 EZ Front Wheel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
72
All Time:
341
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The front wheel on the Shark RV912 EZ allows the robot to pivot and navigate smoothly across floors. If the wheel becomes jammed, worn down, or fails to rotate freely, the robot may drag, veer off course, or stop moving. This guide will show you how to remove and replace the front wheel safely and correctly.
Tools
  • Spudger
    4.9
    1. Shark RV912 EZ Front Wheel Replacement, Front Wheel: step 1, image 1 of 1
      • Flip the robot over and power it off.
      Ask FixBot
    2. Shark RV912 EZ Front Wheel Replacement: step 2, image 1 of 2 Shark RV912 EZ Front Wheel Replacement: step 2, image 2 of 2
      • Slide a rubber spudger under the tire and lift up until a click sounds or the axle releases.
      • Once the wheel lifts out of the pocket, pull it out by hand.
      Ask FixBot
Author
with
Zane Munsinger
469 Reputation
5 Guides authored
Texas Tech, Team 37-6, Allen Fall 2025 Member of Texas Tech, Team 37-6, Allen Fall 2025
TTU-ALLEN-F25S37G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 72
All Time: 341
