Shop the Holiday Gift Guide
Shark RV912 EZ Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
79
All Time:
384
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will walk you through the process of safely removing the old battery and installing a new one, ensuring your Shark RV912 EZ operates efficiently and maintains consistent cleaning power.
Before you begin the repair, make sure the vacuum is off and disconnected from the charger.
Tools
    1. Shark RV912 EZ Battery Replacement, Battery: step 1, image 1 of 1
      • Power off the device using the power button located on the side of the device.
      • Flip the device over to expose the battery compartment.
      Ask FixBot
    2. Shark RV912 EZ Battery Replacement: step 2, image 1 of 2 Shark RV912 EZ Battery Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the pair of 15.4 mm screws securing the battery cover.
      • Lift the battery compartment cover to expose the battery.
      Ask FixBot
    3. Shark RV912 EZ Battery Replacement: step 3, image 1 of 3 Shark RV912 EZ Battery Replacement: step 3, image 2 of 3 Shark RV912 EZ Battery Replacement: step 3, image 3 of 3
      • Use the tabs on the battery to lift it straight out to access the battery connector. Set the battery aside close to the battery compartment.
      • Do not pull on the battery while it is still connected to the device.
      • Use your fingers to squeeze the connector tab and remove it from the socket.
      • Remove the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Zane Munsinger
469 Reputation
5 Guides authored
Texas Tech, Team 37-6, Allen Fall 2025 Member of Texas Tech, Team 37-6, Allen Fall 2025
TTU-ALLEN-F25S37G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 79
All Time: 384
