You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The motor is the powerhouse behind your brush head rotation which could either increase or decrease your vacuum's cleaning power. This guide will take you through the necessary steps to properly replace your motor.
  1. Detach the hose connected on the bottom of the vacuum by pulling it out of the casing. Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Lay the vacuum on its side. Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Flip over the vacuum head so the brush head is facing up.
    • Flip over the vacuum head so the brush head is facing up.
  4. Remove the small front wheels with a metal spudger by inserting the metal spudger in front of  the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it. Repeat this for the other wheel. Repeat this for the other wheel.
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Remove the two 18mm screws with a JIS 1 screwdriver. Remove the two 18mm screws with a JIS 1 screwdriver.
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver. Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver. Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Remove the plastic cover by prying the plastic cover up using a plastic opening tool. Prying in multiple locations may be necessary to create separation. Prying in multiple locations may be necessary to create separation.
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Locate the motor on the top right corner of the vacuum head shell.
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Remove the belt from the motor gear by sliding the belt to the right. Remove the belt from the motor gear by sliding the belt to the right. Remove the belt from the motor gear by sliding the belt to the right.
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Remove the white metal wire connector from the motor. The white cable is positive. The white cable is positive.
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Remove the black metal wire connector from the motor. The black cable is negative.
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Suzie
428 Reputation
4 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
6 Guides authored
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 142
All Time: 2,139
