Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Replacing the roller brush belt will require a metal spudger, a screwdriver, and a plastic opening tool. This replacement can help with the rotation of the roller brush.
  1. Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner. Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Insert the metal spudger between the inside side of the wheel and the plastic body. Push the metal spudger away from you to pop the wheels out. Repeat the step to remove the other wheel on the other side.
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Remove the six 15mm screws using the PH1 screwdriver.
    • Remove the six 15mm screws using the PH1 screwdriver.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Move the blue fulcrum connecting the  bottom and the main body of the vacuum cleaner back and forth to loosen up crevice  between the two halves of the roller brush enclosure. Move the blue fulcrum connecting the  bottom and the main body of the vacuum cleaner back and forth to loosen up crevice  between the two halves of the roller brush enclosure.
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
  6. Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush. Apply an outward force throughout and all around the gap in order to separate the two plastic frames. Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
  7. Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface. Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  8. Lift the roller brush slightly upwards  using your hand. Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand. Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  9. Remove the roller brush belt with your hands by sliding it of the end of the motor.
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
Elena Postupalskaya
832 Reputation
6 Guides authored
Cal Poly, Team S15-G2, Livingston Fall 2017 Member of Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Members
7 Guides authored
Past 24 Hours: 10
Past 7 Days: 101
Past 30 Days: 488
All Time: 9,930
