Introduction
If you are having a problem with your device's charging port, here is a step by step guide to replace a faulty charging port of your Shark Cordless Pet Perfect.
Remove the five 14mm screws with the PH 2 bit. Once all the screws are removed, pull one part of the housing away from the other.
Pull the charging port mount away from the housing. Once separated, pull the the charging port out of the mount to access the charging port itself.
