Shop the Holiday Gift Guide
Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
154
All Time:
492
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 2 hours
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This advanced guide details how to replace the factory Micro-USB port with a durable USB-C receptacle.
This conversion requires precise micro-soldering and mechanical modification of the right ear cup housing. Rushing or improperly executing this procedure risks damaging the housing, destroying PCB traces, or rendering the device permanently unusable. If you lack advanced surface-mount soldering skills, have a qualified technician perform the board-level work.
Technical Specifications
  • USB-C Power Delivery (PD) Compliance: The replacement USB-C port or adapter PCB must incorporate dual 5.1 kΩ pull-down resistors connected individually from the CC1 and CC2 lines to ground. Standard Micro-USB footprints only route VBUS, D-, D+, and GND, meaning the CC configuration resistors must reside directly on the USB-C board. Without these resistors, C-to-C smart chargers and Power Delivery sources will not negotiate 5V and will fail to supply power.
  • Pad and Trace Mapping: Map the original Micro-USB PCB footprint (VBUS, D-, D+, GND) directly to the corresponding solder pads on the USB-C adapter board.
  • Structural Anchoring: USB-C connectors generate higher mechanical insertion and extraction forces than Micro-USB ports. Applying structural epoxy or UV resin along the rear of the port, side seams, and through-hole anchors is mandatory to prevent pad tear-off.
    • A dedicated MicroUSB designed USB-C port avoids this because it has these resistors built into the 5 pin board.
  • Disclaimer: Micro-soldering services were provided locally by iCare Mobile Australia; no commercial affiliation exists. Guide images have been digitally processed using Google Gemini to meet iFixit photographic standards.
Tools
    1. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Earmuff: step 1, image 1 of 1
      • Grab the earmuff with one hand and hold the headphones with the other.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 2, image 1 of 1
      • Pull the earmuff near the top until the seam starts to pull from the split in the headphone case. Continue until the earmuff fully separates from the headphones as shown.
      • NOTE: When re-attaching to the headphone the last few inches have to be stretched, use a blunt opening tool or cotton bud to hook under the membrane and pull into position as you push from the inside with your fingers.
      Ask FixBot
    1. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Charging Port/Volume Control: step 3, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Charging Port/Volume Control: step 3, image 2 of 2
      • After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 4, image 1 of 1
      • When separating the housing be careful not to drop, force or seperate to far apart. You risk damaging the headphone jack cables.
      Ask FixBot
    3. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 5, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 5, image 2 of 2
      • Remove the (3) Screws holding in the shroud. Then gently lift away, (you can manoeuvre it be detached.)
      • Remove the Microphone from the Shroud, Be careful as it's delicate. It has a rubber cover that can be pinched with your fingers and pulled gently upwards, or pried out with small tweezers or pliers.
      • Use tape to hold them out of the way if you need.
      Ask FixBot
    4. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 6, image 1 of 1
      • After locating the circuit board that contains the charging port as well as the volume control dial, Three 3 mm screws must be removed using a #000 phillips screwdriver.
      Ask FixBot
    5. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion: step 7, image 1 of 1
      • NOTE: Use caution lifting up the black clip, it is very fragile, especially on older headphones.
      • Unplug the blue ribbon attaching the circuit board to the motherboard.
      • The Ribbon cable is attached to the foam bridge, force may cause it to tear. Replacement cables are not available and will render the headphone useless if you tear it.
      • Recommended steps.
      • Unclip top connected first
      • Unclip Bottom Connector
      • Use a paperclip rounded end to push on the cable until the cable detaches from bottom connector.
      • One you have replaced the board, follow these steps in reverse. Be careful.
      Ask FixBot
    1. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Prepare USB-C port pre fitting: step 8, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Prepare USB-C port pre fitting: step 8, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Prepare USB-C port pre fitting: step 8, image 3 of 3
      • I have not provided a guide on how to replace the USB-C port directly as I paid a Professional to do this modification. If you don't have the skill set to complete this I recommend you don't try it yourself. The risk of failure is very high. Although I have provided details for those who are skilled in this type of micro soldering.
      • Pay attention to how the board fits into place, It needs to be lined up correctly. There is a 45* angle near the port, and a tiny clip it slots into at the other end. This is how you are going to determine how accurate your filing is to be, were talking fractions of a millimeeter
      • Measure the port from the outside, 90% of your filing should be away from the microphone housing and towards the volume switch.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Filing Enclosure: step 9, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Filing Enclosure: step 9, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Filing Enclosure: step 9, image 3 of 3
      • DO NOT: file the top of the housing, this is thin and you should ONLY file the sides and the bottom, constantly refit, and look for Plastic distortions (over tight fit). Don't make the fit to tight, as this can cause the very thin plastic at the top to break (like mine did) when fitting.
      • Begin: With your round file gently and slowly begin to file the outside edges to be wider to fit your USB-C port.
      • Don't file from outside housing to prevent accidental damage
      • Begin: With a flat file gently file the base the PCB sits on, you may need to use a knife to carve out the bottom corners to allow the PCB to fit flush.
      • Don't file through the headphone jack housing. It's expected that the port sits a fraction higher because of the size of USB-C ports, Some of the PCB may show when looking from Outside closely.
      • Begin filing down the headphone jacks internal base to be flush, if you can leave a small section (see orange marker) slightly higher this will allow your volume toggle to not scrape on the housing.
      • You will know when it's correct as the Board will Clip into place with a small amount of force from the Power button end. See red markers for points to check. (power button, charging light groove, power button toggle)
      • You can use a fingernail buffing board to shine up the plastic to a high gloss and smooth-out the rough external edges. Not to be confused with a Polishing board
      Ask FixBot
    3. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Final check and fit before finish: step 10, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Final check and fit before finish: step 10, image 2 of 2
      • Make sure all the marked points are correctly seated: Power button pushed in with ease and aligned correctly, PCB sits flush against ABS bloc.
      • Some pressure may need to be applied from rear of board to have this section from housing clip into the PCB notch. (very careful)
      • Check USB-C port measurements from the outside to see the tightness of the fit. there should be no Distortion, and a Small gap where you can see the PCB from the outside.
      • Depending on your port and if you left it stock or filed it down, It will stick out of the housing about 1mm. If when you screw the board back into the main housing and you didn't leave that little raised corner, your Volume button may rub against the housing. This can be fixed by loosening the screw to allow a smoother fit.
      • If you would like, you can fill in This small gap exposing the PCB with some Clear Rubber Glue (I use Shoe repair Glue as It sets like rubber allowing it to be removed later and not become brittle)
      Ask FixBot
    4. Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Finish You can put your Device back together now, following the steps in reverse.: step 11, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Finish You can put your Device back together now, following the steps in reverse.: step 11, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Micro-USB to USB-C Conversion, Finish You can put your Device back together now, following the steps in reverse.: step 11, image 3 of 3
      • Test USB-C to USB-C Cable, Does it Charge?
      • Test USB-A to USB-C Cable, Does it charge?
      • Red flashing light (Dead flat), Blue/Purple (Charging)
      Ask FixBot
The MicroUSB to USB-C soldering was completed by iCare Mobile SunshineCoast Queensland Australia
Author
with
Narcarsiss
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 154
All Time: 492
