Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
How to repair the speakers of a Sega Game Gear.
Parts
No parts specified.
Video Overview
  1. Place your device upside down and locate the two battery compartments.
    • Place your device upside down and locate the two battery compartments.
  2. Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Remove the following screws:
    • Remove the following screws:
    • Seven Phillips screws
    • One 4.5 mm Gamebit screw
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Use tweezers to take all other screws out.
    • Use tweezers to take all other screws out.
  6. Gently open the case by unfolding it over the top of the Sega Game Gear. Do not pull the back of the case away, as cables are connected between both sides.
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  7. Carefully unplug the 2 white-tipped connectors on the top cover. Carefully unplug the 2 white-tipped connectors on the top cover. Carefully unplug the 2 white-tipped connectors on the top cover.
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  8. Unscrew the 8 Phillips screws from the logic board.
    • Unscrew the 8 Phillips screws from the logic board.
  9. Slide the logic board out from under the circular black fastener at the top-left corner of the case.
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  10. Removing the plastic holding the speaker to the case may  permanently detach the speaker. The plastic at these three locations is melted to the plastic. Pry off with caution.
    • Removing the plastic holding the speaker to the case may permanently detach the speaker.
    • The plastic at these three locations is melted to the plastic. Pry off with caution.
Lauren Thurston
343 Reputation
3 Guides authored
Cal Poly, Team 28-33, Regan Spring 2010 Member of Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 48
All Time: 9,890
