Corded Dexter Jigsaw 750 Watts Blade Holder Replacement
  1. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement, Unplug: step 1, image 1 of 1
    • Before starting, remember to unplug the device.
  2. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 2, image 1 of 1
    • Remove the vacuum hose adapter at the back of the device.
  3. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 3, image 1 of 2 Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 3, image 2 of 2
    • With the help of a screwdriver, unscrew and open the device.
    • Use the lever to unlock the cover.
    • Using pliers, remove the clip beside the blade holder.
    • Take off the blade holder, then raise the slide located at the end of the holder.
  4. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 6, image 1 of 1
    • First, put the slide onto the new blade bracket.
    • Put the blade bracket back in its place.
    • Make sure to properly put each piece back in its place.
    • Replace the clip in the same place. The curved side of the clip needs to go into the round side of the bracket.
    • Lubricate.
  5. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 9, image 1 of 1
    • Close and screw the device back together.
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
36 Members
239 Guides authored
One Comment
Bonjour,
Je suis intéressé pour changer ce support de lame, le mien étant défectueux … les lames ne tiennent plus. Ou est-ce que je peux trouver cette pièce ? Merci Bruno
Bruno - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 77
All Time: 3,095
