Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: step 1, image 1 of 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: step 1, image 2 of 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: step 2, image 1 of 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: step 3, image 1 of 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Austin
201 Reputation
2 Guides authored
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Member of WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 286
