Introduction
Proving once again that thin and light can still be repairable when thoughtfully designed, the Series 9 15" scores a near-perfect 9 out of 10.
  1. Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: step 1, image 1 of 3 Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: step 1, image 2 of 3 Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: step 1, image 3 of 3
    • Reference shots.
  2. Samsung Series 9 15" Repairability Assessment: step 2, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 2, image 2 of 2
    • Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off.
    • It's clipped in along the back edge but not very strongly.
    • Internal view.
    • This is seriously cool. From here we can remove: SSD, RAM, battery, right speaker, display assembly, wireless card, (modular!) headphone jack and thermal assembly.
    • That's pretty much everything you'd ever want to tinker with in a laptop. The only commonly-replaced components we can't reach is the keyboard, trackpad, and motherboard.
  3. Samsung Series 9 15" Repairability Assessment: step 3, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 3, image 2 of 2
    • To keep things uniform, we're starting with the battery.
    • It's held in with seven Phillips screws and comes out in a flash.
  4. Samsung Series 9 15" Repairability Assessment: step 4, image 1 of 3 Samsung Series 9 15" Repairability Assessment: step 4, image 2 of 3 Samsung Series 9 15" Repairability Assessment: step 4, image 3 of 3
    • We then start picking parts off the motherboard and the peripheries.
    • Along the way, we discover room for not one, but two RAM modules.
    • That addition, along with the standard, removable SSD means this laptop is super upgradable.
  5. Samsung Series 9 15" Repairability Assessment: step 5, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 5, image 2 of 2
    • We could remove the motherboard at this point, but pause to take a look at this trackpad.
    • Seemingly held in place with just five screws, but we remove them and it won't budge.
    • Then we peel off this pair of taped-in brackets, pry from the top bracket, and successfully remove the trackpad assembly.
  6. Samsung Series 9 15" Repairability Assessment: step 6, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 6, image 2 of 2
    • Next up is the fan. It's secured with two screws.
    • And the daughterboard. After unscrewing three Phillips screws it will not budge, so we had to break up the adhesive holding it in.
  7. Samsung Series 9 15" Repairability Assessment: step 7, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 7, image 2 of 2
    • Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge.
  8. Samsung Series 9 15" Repairability Assessment: step 8, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 8, image 2 of 2
    • Finally we remove three screws from each of the display hinges and the display assembly is free.
  9. Samsung Series 9 15" Repairability Assessment: step 9, image 1 of 2 Samsung Series 9 15" Repairability Assessment: step 9, image 2 of 2
    • The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • All screws are Phillips screws.
    • RAM, SSD, and battery are all easily replaced.
    • Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
    • A moderate amount of adhesive on the I/O board and trackpad brackets complicates some reassembly procedures.
    • Manufacturer does not provide user-accessible repair documentation.
Finish Line
10 other people completed this guide.
Evan Noronha
214,557 Reputation
177 Guides authored
The Home Depot Member of The Home Depot
Community
9,622 Members
1,024 Guides authored
2 Comments
how would one repair water vapor trapper in between the touch panel glass?
cooperbeaman - Reply
Sadly when you pulled back the bezel you missed that it’s not a separate LCD but part of the top cover those screws at the bottom just hold a panel in place at the bottom.
Good guide otherwise.
Gaspard Leon - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 146
All Time: 11,798
