Introduction
With this guide you can clean or repair a faulty keypad.
Tools
Parts
No parts specified.
Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
Some force must be applied, and the back cover should come off.
Use the Ipod Opening Tool to lift the green logic board carefully.
Remove the logic board from the device.
The keypad should peel off the logic board with a gentle pull.
Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
