Samsung Powebot VR9000 Battery Replacement
  1. Samsung Powebot VR9000 Battery Replacement, Battery: step 1, image 1 of 2 Samsung Powebot VR9000 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn off the emergency switch located at the bottom right of the POWERbot.
  2. Samsung Powebot VR9000 Battery Replacement: step 2, image 1 of 2 Samsung Powebot VR9000 Battery Replacement: step 2, image 2 of 2
    • Unscrew the two 6mm Phillips #1 screws and remove the lid, exposing the battery.
  3. Samsung Powebot VR9000 Battery Replacement: step 3, image 1 of 2 Samsung Powebot VR9000 Battery Replacement: step 3, image 2 of 2
    • Follow the wires and find the small white box next to the battery.
    • On the side of the white box facing the battery, find the rigid tab.
  4. Samsung Powebot VR9000 Battery Replacement: step 4, image 1 of 1
    • Push the tab inwards to the white box and pull the wires up. This will release the wires from the white box, allowing you to remove the battery.
  5. Samsung Powebot VR9000 Battery Replacement: step 5, image 1 of 2 Samsung Powebot VR9000 Battery Replacement: step 5, image 2 of 2
    • Remove the battery by holding the battery in place and partially righting the POWERbot so the battery falls out.
4 other people completed this guide.
Alexandra Jensen
138 Reputation
1 Guide authored
Cal Poly, Team S15-G3, Banghart Spring 2017 Member of Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 36
All Time: 6,047
