Introduction
Replace the left wheel of your POWERbot. This can be done to resolve a persistent error code (C 02) and/or to simply eliminate movement issues.
Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
I needed to replace the left drive wheel on a SR20J9250U model. It is largely the same and many parts have VR9000H stamped on them. I will add any differences as I see them.
For this step, there are three clips plus the clip in front of the wheel on each side. First clip is approx 6 cm from the centre at the back. Next is approx 11cm from the first clip and the third is 11 cm from the second clip (almost above the wheel). Then there is the clip in front of each wheel that you can see.
Remove the three 6mm Phillips #1 screws in the holes near the back of the device.
Remove the top chassis from the POWERbot by grabbing the wheel covers and lifting upwards.
Remove the two 5mm Phillips #1 screws in the holes closest to the left wheel.
26 other people completed this guide.
9 Comments
Thanks for the info but can you tell me where I can get the wheel assembly as I think the motor has burned out. Thanks
Thank you so much :) … You helped me save all the money that I have spent on the Samsung Powerbot as I thought there is no way to fix it !
Can't Thank you enough Kyle ;)
Thanks for your information, also I would like to find the spare parts of wheel assembly . Can you recommend me for seller and prices?
October 23, 2018
Narit pukkapan
The instruction worked out great, however there were two flat rubber pieces that fell out of the vacuum during the disassembly. Any idea where they came from? The vacuum worked great for two days, but now it’s not charging any more. I’m wondering if the rubber pieces, which I left out, had something to do with it.
as i’m going through ebay I see alot of Samsung power-bots with broken left wheels where the spring breaks does anyone know why that happens as it happend to me
How much volt does the wheel’s motor requires?
