Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement
  1. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Open the refrigerator doors: step 2, image 1 of 2 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Open the refrigerator doors: step 2, image 2 of 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice bucket: step 3, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice bucket: step 3, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice bucket: step 3, image 3 of 3
    • The ice bucket should be located in the upper left side of your refrigerator.
    • Pull the release lever forward to unlatch the ice bucket.
  4. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 4, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 4, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 4, image 3 of 3
    • Pull the ice bucket out of the ice maker room.
    • If your ice bucket is frozen shut, follow this guide to defrost the ice bucket.
    • Check for cracks or fractures in the ice bucket and auger assembly.
    • Check the gasket on the back of the faceplate of the ice bucket and auger assembly. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly, and may ice up. Replace the bucket as needed.
    • Check the sealing rim around the edge of the ice room opening for ice or cracking.
  5. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Unfasten the cable cover: step 5, image 1 of 1
    • Remove the screw securing the cable cover.
  6. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the cable cover: step 6, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the cable cover: step 6, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the cable cover: step 6, image 3 of 3
    • Use your fingers to pull the front edge of cable cover out from the side of the ice room.
    • You may need a spudger or small flat blade screwdriver to help start this procedure.
  7. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 7, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 7, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 7, image 3 of 3
    • Slide the cable cover out toward the front of the ice room by pulling the front edge.
    • Make sure to slide the cover out to the front and don't try to pull it sideways as you might break the tabs which secure the rear of the cover.
    • During reassembly, take your time and make sure to slide this part in until it goes back flush. Take care not to break the tabs. Check that the screw holes align and all the tabs show in the pockets on the cover and the entire edge of the cover is flush.
  8. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Disconnect the ice maker and ice auger cablesUnfasten the air tunnel: step 8, image 1 of 1
    • Locate the ice maker and ice auger motor connectors.
  9. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 9, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 9, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 9, image 3 of 3
    • Squeeze the locking tab to release the connector and pull it to disconnect.
    • Repeat this for the other connector.
    • Disconnecting both cables will ease removal of the icemaker cable from the cable guide.
  10. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice maker: step 10, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice maker: step 10, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement, Remove the ice maker: step 10, image 3 of 3
    • Remove both cables from the cable guide channel.
    • Depress the locking tab at the top of the ice maker.
    • You should hear a click when the tab releases. This may take some force.
  11. Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 11, image 1 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 11, image 2 of 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: step 11, image 3 of 3
    • Pull the icemaker toward you.
    • It should drop down as you pull it toward you off the mounting bosses. This should occur after it moves about 2-3cm (3/4-1").
    • Lower and remove the icemaker from the ice room.
    • During reassembly, hold the icemaker so it is level and flush to the top of the ice room.
    • Then push it back into the ice room so that the bosses near the front of the ice room engage the oval slots on the ice maker, and the rear lip of the icemaker engages the rim at the rear of the ice room.
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
Bill Gilbert
38,801 Reputation
261 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 40
All Time: 579
