Introduction
The battery is located inside the camera. To remove the battery, it will require uninstalling the battery housing. This can be done in a few steps found below.
Parts
No parts required.
To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
5 other people completed this guide.
