Samsung Gravity TXT microSD Card Replacement
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: step 1, image 1 of 2 Samsung Gravity TXT microSD Card  Replacement, Battery: step 1, image 2 of 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: step 2, image 1 of 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: step 3, image 1 of 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 1 of 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 2 of 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 3 of 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Mounir Karmada
465 Reputation
4 Guides authored
IUPUI, Team 1-1, Renguette SU 2015 Member of IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 204
