Introduction
Go to step 1 ↓This is a guide detailing the removal and replacement of the charging port for the Samsung Galaxy XCover Pro (SM-G715U). The charging port enables the device to receive power and connect for data transfer, and replacement may be necessary if the phone won’t charge, only charges at certain angles, or has an inconsistent connection. Make sure that there is also no moisture in your charging port, as causes and solutions are linked here: Samsung Phone Moisture Detected in Charging Port. However, first rule out simpler issues like a faulty cable, adapter, or overheating. Before starting, power off the device, remove the back cover and battery, and work carefully to avoid damaging internal components. After completing the guide, reconnect everything securely, reinsert the battery, and reassemble the phone, then test charging functions. If problems persist, the issue may be deeper within the motherboard or power circuit and may require professional repair.
Using a heat gun, or a hair dryer on high, heat the screen, focusing on the edges around the screen to melt the glue holding the screen on.
Remove the ribbon cable connecting the charging port board (bottom) and the motherboard (top).
