Introduction
A damaged screen makes viewing anything on the tablet difficult. Removing the screen may require a heat gun or an iOpener. Check out this iOpener guide for instructions on how to use it.
  1. Apply the heat gun around the edges of the tablet to melt the adhesive glue. Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Apply the suction to the bottom or top right corner. Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Once the screen is detached, open the tablet like a book.
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  5. Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  6. Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
2 other people completed this guide.
Joy Harris
741 Reputation
7 Guides authored
USF Tampa, Team S3-G4, Sullivan Spring 2017 Member of USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
3 Members
14 Guides authored
2 Comments
Hí, my Tab S2 has been to a Samsung Service Center for screen replacement, after which they had to open it again, they were not very skilled professionals, and now my screen is not attached to the frame, it is popping out on all sides. Is there a way to glue in the display? Is there a replacement adhesive available?
Gabor - Reply
Hi, my Samsung Tab S2 9.7 has been at a Samsung shop for a new LCD, and they had to reopen it again after the new display has been installed. They were not very skilled professionals. Now my display is not attached to the frame properly and is lifting 1-2mm out of the frame, on all sides, and feels loose. Is there a replacement adhesive to attach the display properly? Or is there some other way to glue in the display? Thanks.
Gabor - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 53
All Time: 1,279
