Samsung Galaxy Tab Pro 10.1 Motherboard Replacement
  1. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: step 1, image 1 of 2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: step 1, image 2 of 2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: step 2, image 1 of 2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: step 2, image 2 of 2
    • Remove the six 4 mm Phillips #00 screws that hold the battery in place.
  3. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 3, image 1 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 3, image 2 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 3, image 3 of 3
    • Remove the tape that runs along the length of the battery.
    • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
    • Remove the two ribbon cables that lay across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  4. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic tweezer and remove the top center 6 pin power connector that is attached to the edge of the motherboard.
    • Detach the battery by gently lifting the battery out of the panel.
  5. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: step 5, image 1 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: step 5, image 2 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: step 5, image 3 of 3
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
  6. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: step 6, image 1 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: step 6, image 2 of 3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: step 6, image 3 of 3
    • Use plastic tweezers and carefully detach the rear-facing camera from the motherboard.
  7. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the five ribbon cables holding the motherboard together with a plastic tweezer.
  8. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 8, image 1 of 2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 8, image 2 of 2
    • Remove the Phillips #00 screws from the plastic part holding down the motherboard.
  9. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: step 9, image 1 of 1
    • Gently lift the motherboard from the front panel enclosure.
4 other people completed this guide.
Stephen Yeung
1,526 Reputation
6 Guides authored
3 Comments
very useful,thanks a lot.
Singh
bandna kaur matta - Reply
ارغب باصلاح شريحة الاتصال
mazinmandour - Reply
Thanks for this manual. Can you help me recognise the Wifi/BT module? I have a problem with that - with some luck it is just the connector....
Arno - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 6,368
