Samsung Galaxy Tab A Motherboard Replacement
  1. Samsung Galaxy Tab A Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy Tab A Motherboard Replacement: step 2, image 2 of 2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the bent precision tweezers to disconnect the battery connector from the motherboard.
    • Avoid touching the motherboard with the tweezers. Metal tools such as the tweezers can scratch the motherboard and potentially cause damage.
  4. Samsung Galaxy Tab A Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Tab A Motherboard Replacement: step 4, image 2 of 2
    • Use the spudger to disconnect the flexible display cable connector from the motherboard.
    • The first and second pictures show what the display looks like when it is still connected to the motherboard and once it is disconnected, respectively.
  5. Samsung Galaxy Tab A Motherboard Replacement: step 5, image 1 of 2 Samsung Galaxy Tab A Motherboard Replacement: step 5, image 2 of 2
    • Use the spudger to flip up the ZIF connector to unlock the rear facing camera's flexible cable.
    • Then use tweezers to gently remove the rear facing camera from the device.
  6. Samsung Galaxy Tab A Motherboard Replacement: step 6, image 1 of 1
    • Use the spudger to flip up the ZIF connector to unlock the front facing camera's flexible cable.
    • Then use tweezers to gently remove the front facing camera from the device.
  7. Samsung Galaxy Tab A Motherboard Replacement: step 7, image 1 of 1
    • Use the spudger to disconnect the LCD panel's flexible cable connector.
  8. Samsung Galaxy Tab A Motherboard Replacement: step 8, image 1 of 1
    • Use the spudger to disconnect the 3.5mm headset jack's flexible cable connector.
  9. Samsung Galaxy Tab A Motherboard Replacement: step 9, image 1 of 2 Samsung Galaxy Tab A Motherboard Replacement: step 9, image 2 of 2
    • Use the PH0 screwdriver bit to remove the two 3 mm screws connecting the USB port shield to the midframe.
    • Then use the spudger tool to remove the USB port shield.
  10. Samsung Galaxy Tab A Motherboard Replacement: step 10, image 1 of 2 Samsung Galaxy Tab A Motherboard Replacement: step 10, image 2 of 2
    • Use the PH0 screwdriver bit to remove the two 3 mm screws on the left side of the motherboard.
  11. Samsung Galaxy Tab A Motherboard Replacement: step 11, image 1 of 3 Samsung Galaxy Tab A Motherboard Replacement: step 11, image 2 of 3 Samsung Galaxy Tab A Motherboard Replacement: step 11, image 3 of 3
    • Using the flat end of a spudger, carefully wedge the motherboard from the case.
    • Be patient, using gentle and even force, while wedging the motherboard out of the midframe with the spudger. Excessive flexing of the board may cause damage to components or circuit traces.
    • Using your fingers, gently remove the motherboard out of the device.
    • Once the motherboard is removed, the device should look like as illustrated in the third picture.
Michael Wozny
3,738 Reputation
5 Guides authored
USF Tampa, Team 17-4, Blackwell Winter 2016 Member of USF Tampa, Team 17-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G4
4 Members
12 Guides authored
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 94
All Time: 24,305
