Samsung Galaxy Tab 8.9 Speaker(s) Replacement
  1. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert Opening tool: step 1, image 1 of 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Insert second tool: step 2, image 1 of 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 3, image 1 of 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 4, image 1 of 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Speaker(s) Replacement, Charging Port: step 5, image 1 of 1
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 6, image 1 of 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 6, image 2 of 2
    • Insert a spudger under the orange tab.
    • Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 7, image 1 of 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 8, image 2 of 2
    • Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
  9. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 9, image 1 of 1
    • Insert opening tool to pry support from the housing.
  10. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 10, image 1 of 2 Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 10, image 2 of 2
    • Desolder the two connections to separate the speakers from the charger port.
  11. Samsung Galaxy Tab 8.9 Speaker(s) Replacement: step 11, image 1 of 1
    • Separate charging port from speaker assembly.
Eric Bird
543 Reputation
5 Guides authored
IUPUI, Team S4-G2, Harley Spring 2017 Member of IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 134
