Samsung Galaxy Tab 4 7.0 Camera Replacement
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: step 1, image 2 of 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 2, image 1 of 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 3 of 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 3 of 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 5, image 2 of 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 6, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 6, image 2 of 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - Reply
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 3 of 3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
9 other people completed this guide.
Aubrey Goodwin
2,700 Reputation
3 Guides authored
USF Tampa, Team 1-3, Remmell Fall 2015 Member of USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Members
12 Guides authored
3 Comments
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Reply
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Reply
टॅब पार्ट खरेदी करना है मुझको
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,268
