Introduction
Before beginning, please buy the replacement rear camera for the Samsung Galaxy Tab 4 10.1.
Parts
No parts required.
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Use the nylon spudger to lift the camera out of the motherboard by wedging it under both sides and gently prying up.
  • Use the nylon spudger to lift the camera out of the motherboard by wedging it under both sides and gently prying up.
Once the camera is loose, lift it out of the device.
  • Once the camera is loose, lift it out of the device.
  • Use a little glue to help the new camera stick in place.
Parth Parikh
410 Reputation
2 Guides authored
Cal Poly, Team 18-1, Forte Fall 2016 Member of Cal Poly, Team 18-1, Forte Fall 2016
CPSU-FORTE-F16S18G1
5 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 419
