Introduction
Before starting, please buy the the replacement Micro USB for the Samsung Galaxy Tab 4 10.1.
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
  • Peel off the green tape that covers the connectors for the three black strips.
  • Use the tip of a spudger or your fingernail to flip up the small retaining flap.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Use a Phillips #00 screwdriver screwdriver to remove the four 3.2mm screws.
  • Use a Phillips #00 screwdriver screwdriver to remove the four 3.2mm screws.
Use the nylon spudger to remove the native tab by wedging it under each side and prying up.  Then, lift it straight up from its socket.
  • Use the nylon spudger to remove the native tab by wedging it under each side and prying up. Then, lift it straight up from its socket.
Carefully pull out the charging port.
  • Carefully pull out the charging port.
  • This may take some force because of the sticky glue.
7 other people completed this guide.
Parth Parikh
340 Reputation
2 Guides authored
Cal Poly, Team 18-1, Forte Fall 2016 Member of Cal Poly, Team 18-1, Forte Fall 2016
CPSU-FORTE-F16S18G1
5 Members
3 Guides authored
Past 24 Hours: 8
Past 7 Days: 61
Past 30 Days: 317
All Time: 2,293
