Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart. Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
  • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
Peter how do I know which charging port I need thank you I don't know how else to reach you Tom Patrick mlc@earthlink.net all small case and no spaces thank you
Tom Patrick - Reply
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove
  • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
  • Note: the connection lifts up to remove
After the battery is disconnected you may use your hands to pull out the battery. It may be a little difficult because there is adhesive on the backside of the battery.
  • After the battery is disconnected you may use your hands to pull out the battery. It may be a little difficult because there is adhesive on the backside of the battery.
You don't have to, just be careful with battery connector.
Kyoko Hori - Reply
You have to be very careful with the battery connector. On mine, the plug was difficult to remove from the base and I ended up breaking the connections between the base and the circuit board. Maybe use the pry tool to hold the base down while easing out the plug.
Hugh Morrison - Reply
I just did the same thing Hugh...does that mean my tablet is trashed? Can it be repaired?
tlibert -
Disconnect the relays attached to the motherboard. Disconnect the relays attached to the motherboard. Disconnect the relays attached to the motherboard.
  • Disconnect the relays attached to the motherboard.
Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device. Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device. Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device.
  • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board. Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
  • Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery. Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery. Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  • Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
Carefully lift the board from the device. Carefully lift the board from the device.
  • Carefully lift the board from the device.
remove camera mentioned in step 7 before doing this
as well as disconnecting the 3 connectors at the bottom n vm
also note that the top left black square comes out with the motherboard
Kerri - Reply
With a plastic remover tool, gently unseat the connection of the proximity sensor to the motherboard.
  • With a plastic remover tool, gently unseat the connection of the proximity sensor to the motherboard.
Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor.  The Sensor can then simply lifted from the device. Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor.  The Sensor can then simply lifted from the device. Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor.  The Sensor can then simply lifted from the device.
  • Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor. The Sensor can then simply lifted from the device.
Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device. Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device. Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device.
  • Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device.
Hey Mr. fix it how can I get in contact with you to get a charging port I can't seem to find mine anywhere my name is Tom and my phone number is 7175332039I hope you see this if anybody else does that knows where I can get one give me a call thank you
Tom Patrick - Reply
9 other people completed this guide.
Kyle Ballard
638 Reputation
3 Guides authored
USF Tampa, Team 4-2, Brown Fall 2014 Member of USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Members
11 Guides authored
5 Comments
This doesn't seem to address the digitizer directly... is it self evident how to replace it once the back cover is removed?
Marc Stuart - Reply
NOTE!
you will not be able to replace just the touch screen. You will need a digitizer/LCD assembly. At this moment in time it is cheaper to buy a working pre-owned tab than buying and fitting a new assembly. Beware of ebay and other seller that supply the digitizer only you will not be able to fit it you need a complete assembly.
Dan -
This guide is seriously lacking detail, especially the very first step. All it says is to do is pry it open. Wrong. First of all don't even touch the screen until you have pried the rear plastic cover off first. That can be achieved by using a very thin plastic tool or metal tool if you are careful. There are snaps holding it in place so you will have to twist the tool to pop the tabs. Very tricky. The top glass has several cables that you will slice through if you don't know where they are when prying the top off. The audio jack at the top being one and the buttons on the bottom being the others. Take off the rear first disconnect audio jack cable and battery first!!!
Sam - Reply
I have to remplace the digitizer for this tab but 7.0 - the digitizer works fine when the tab is out the rear plastic cover. When i put the plastic cover, i have a line who doesnt work on the digitizer, any idea ?
Adrien Ould Madi - Reply
I have seen videos and know the digitizer doesn't require all the steps mentioned here. You only remove the back, unplug the battery and digitizer cables the heat the edges of the screen to loosen the adhesive then pry it off and replace with new digitizer then just put it back togather. All the stuff he has you doing only half of what needs to be done if your replacing the screen itself. Which I have to do now my daughter broke mine.
Fernando White - Reply
Past 24 Hours: 18
Past 7 Days: 64
Past 30 Days: 259
All Time: 12,948
