Samsung Galaxy Star Pro Motherboard Replacement
  1. Samsung Galaxy Star Pro Motherboard Replacement, Battery Replacement: step 1, image 1 of 1
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Samsung Galaxy Star Pro Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy Star Pro Motherboard Replacement: step 2, image 2 of 2
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Samsung Galaxy Star Pro Motherboard Replacement, Screen: step 3, image 1 of 1
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  4. Samsung Galaxy Star Pro Motherboard Replacement: step 4, image 1 of 1
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  5. Samsung Galaxy Star Pro Motherboard Replacement: step 5, image 1 of 1
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  6. Samsung Galaxy Star Pro Motherboard Replacement, Motherboard: step 6, image 1 of 2 Samsung Galaxy Star Pro Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
3 other people completed this guide.
Kevin Teque
294 Reputation
2 Guides authored
2 Comments
more information please....
me good - Reply
What information are you looking for?
Kelsea Weber -
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 3,124
