Samsung Galaxy S5 Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy S5 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
    • Carefully wedge the tip of a spudger underneath the antenna cable connector.
    • Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
  2. Samsung Galaxy S5 Motherboard Assembly Replacement: step 2, image 1 of 1
    • Remove the single 3.0 mm Phillips #000 screw securing the motherboard to the midframe.
  3. Samsung Galaxy S5 Motherboard Assembly Replacement: step 3, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement: step 3, image 2 of 2
    • Pull, but do not remove, the camera end of the motherboard up from the midframe to allow access to the connectors on the rear.
    • Do not attempt to fully remove the motherboard as it is still attached to the interior midframe by the Micro-USB port daughterboard connector.
  4. Samsung Galaxy S5 Motherboard Assembly Replacement: step 4, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement: step 4, image 2 of 2
    • Use the flat end of a spudger to pry the daughterboard connector straight up off its socket on the motherboard.
Sam Goldheart
465,738 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,767 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 360
