Introduction
Pre-req guide on disconnecting the battery on the Galaxy S20 Ultra.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave your opening pick in the seam to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
Slide the pick towards the bottom edge of the phone to separate the back cover's adhesive.
Leave your pick under the left edge of the glass near the bottom of the device to prevent the adhesive from resealing.
Insert another pick under the center of the left edge of the back cover.
Gradually slide the pick towards the top of the device to separate the back cover's adhesive.
Leave your pick under the left edge of the glass near the top of the device to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Leave your pick under the right edge of the glass near the bottom of the device to prevent the adhesive from resealing.
Insert another pick underneath the center of the right edge of the back cover.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Tool used on this step:Magnetic Project Mat$19.95
Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to unclip and remove the motherboard bracket.
