Samsung Galaxy Note USB Board Replacement
  1. Samsung Galaxy Note USB Board Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Stylus: step 1, image 2 of 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note USB Board Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note USB Board Replacement: step 3, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 3, image 2 of 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note USB Board Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Battery: step 4, image 2 of 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 1 of 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 2 of 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 3 of 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note USB Board Replacement: step 6, image 1 of 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note USB Board Replacement, SIM Card: step 7, image 1 of 2 Samsung Galaxy Note USB Board Replacement, SIM Card: step 7, image 2 of 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note USB Board Replacement: step 8, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 8, image 2 of 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note USB Board Replacement, Midframe: step 9, image 1 of 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note USB Board Replacement: step 10, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 10, image 2 of 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note USB Board Replacement: step 11, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 11, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 11, image 3 of 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note USB Board Replacement: step 12, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 12, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 12, image 3 of 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note USB Board Replacement: step 13, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 13, image 2 of 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: step 14, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: step 14, image 2 of 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note USB Board Replacement: step 15, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 15, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 15, image 3 of 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note USB Board Replacement: step 16, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 16, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 16, image 3 of 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note USB Board Replacement: step 17, image 1 of 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note USB Board Replacement: step 18, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 18, image 2 of 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note USB Board Replacement, USB Board: step 19, image 1 of 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  20. Samsung Galaxy Note USB Board Replacement: step 20, image 1 of 1
    • Lift the speaker enclosure from the display assembly.
  21. Samsung Galaxy Note USB Board Replacement: step 21, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 21, image 2 of 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  22. Samsung Galaxy Note USB Board Replacement: step 22, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 22, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 22, image 3 of 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  23. Samsung Galaxy Note USB Board Replacement: step 23, image 1 of 1
    • Remove the USB board.
Sam Goldheart
465,762 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 24,373
