Introduction
Prereq to remove the motherboard.
Use a spudger to disconnect the vibrator/power button assembly cable connector.
Disconnect the antenna cable connector.
Disconnect the display cable connector.
Disconnect the front-facing camera cable connector.
Disconnect the headphone jack cable connector.
Disconnect the digitizer cable connector.
Use the spudger to disconnect the antenna cable connector from the motherboard.
Disconnect the soft button cable connector.
Disconnect the USB board cable connector.
