Fix Your Stuff
Right to Repair
Store
Introduction
This guide will walk you through the process of replacing a not working back camera in a Samsung Galaxy J3V.
  1. Place your thumb on the top left corner and pry the tab open and lift off the back cover. Place your thumb on the top left corner and pry the tab open and lift off the back cover. Place your thumb on the top left corner and pry the tab open and lift off the back cover.
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards. If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off. If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Use tweezers to flip tab of the front camera to remove it. Use tweezers to flip tab of the front camera to remove it. Use tweezers to flip tab of the front camera to remove it.
    • Use tweezers to flip tab of the front camera to remove it.
  5. Remove connector tab with spudger then carefully remove headphone jack with tweezers. Remove connector tab with spudger then carefully remove headphone jack with tweezers. Remove connector tab with spudger then carefully remove headphone jack with tweezers.
    • Remove connector tab with spudger then carefully remove headphone jack with tweezers.
  6. Remove these connectors from the motherboard with spudger. Remove these connectors from the motherboard with spudger.
    • Remove these connectors from the motherboard with spudger.
  7. Carefully use the spudger to pry the motherboard out of the plastic tabs. Carefully use the spudger to pry the motherboard out of the plastic tabs.
    • Carefully use the spudger to pry the motherboard out of the plastic tabs.
  8. After removing the motherboard, locate and flip tab holding the rear camera's connector. Carefully use the tweezer to remove the connector and the camera. Carefully use the tweezer to remove the connector and the camera.
    • After removing the motherboard, locate and flip tab holding the rear camera's connector.
    • Carefully use the tweezer to remove the connector and the camera.
Carry Corrales
711 Reputation
5 Guides authored
USF Tampa, Team S3-G3, Nance Fall 2017 Member of USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
4 Members
5 Guides authored
One Comment
Your &&^&^$^ trash and did not help me at all.
Harrington Kenneth - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 1,015
