Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement
Video Overview
  1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: step 1, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: step 1, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: step 1, image 3 of 3
    • Here we have Samsung Galaxy J1 with broken glass and screen.
    • We will replace the touch screen and the LCD.
    • First remove the battery and any installed SIM and memory cards.
  2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 2, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 2, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 2, image 3 of 3
    • Under this plastic is the LCD flex cable connector.
    • Use a tool with a needlepoint and remove it.
  3. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 3, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 3, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 3, image 3 of 3
    • Disconnect the LCD flex cable.
    • When I can, I always test new replacement part before I install it.
  4. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 4, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 4, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 4, image 3 of 3
    • Use hot air to warm the glass and to make adhesive soften.
    • With a cutter or knife start the separation.
    • When you have enough space between the glass and the frame, continue with a plastic tool.
  5. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 5, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 5, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 5, image 3 of 3
    • You can warm the glass again to make the separation more easy.
    • If you want to change only the touch screen, be careful, don't break the LCD.
    • Finally remove the screen and the glass from the frame.
  6. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 6, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 6, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 6, image 3 of 3
    • If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
  7. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 7, image 1 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 7, image 2 of 3 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 7, image 3 of 3
    • Connect the touch screen to the LCD flex cable.
    • Put the LCD and the screen in their place.
    • Remove the protector from the touch screen.
    • Install the earpiece metal plate - take it from the old touch screen.
    • Remove the protector from the LCD (if it's new).
  8. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 8, image 1 of 2 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: step 8, image 2 of 2
    • Connect the LCD flex cable and you are ready.
113 other people completed this guide.
ZFix
191,182 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,521 Guides authored
24 Comments
Bonjour, ou peux t on trouver l'écran et la vitre de protection ? Merci d'avance
Romain - Reply
How much is the cost for Galaxy J1 replacement glass?
Charles Young - Reply
It costs from 18€ up to 25€.
Johannes Franzen -
Gracias bro .. se ve interesante el único problema es que no se muy bien el ingles
Luis Fernando Ibarra casquete - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 71
All Time: 148,087
