Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
You will be learning how to replace the motherboard.
  1. Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame. Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
  2. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver. One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty. Use the plastic removal tool to work pry the mid-frame from the device.
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone. Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone. Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
    • Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
  5. Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
    • Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
  6. On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place. Keep these screws separate from the back plate screws.
    • On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
    • Keep these screws separate from the back plate screws.
5 other people completed this guide.
Taylor
1,165 Reputation
5 Guides authored
USF Tampa, Team 16-6, Watkins Winter 2015 Member of USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Members
5 Guides authored
One Comment
How to jumper network problem
Kshitiz khadka - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 976
