Samsung Galaxy A8(2018) Back Cover Replacement
  1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: step 1, image 1 of 2 Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: step 1, image 2 of 2
    • Turn off your phone.
    • Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
    • The adhesive is distributed over the outline of the back cover shown in red in the photo.
  2. Samsung Galaxy A8(2018) Back Cover Replacement: step 2, image 1 of 1
    • Use a suction cup to lift the back cover and insert an opening pick into the slot created.
    • Start in the middle and cut the adhesive while maintaining tension on the suction cup.
    • If you find it increasingly difficult to move the pick, reheat the iOpener or use a hair dryer.
  3. Samsung Galaxy A8(2018) Back Cover Replacement: step 3, image 1 of 2 Samsung Galaxy A8(2018) Back Cover Replacement: step 3, image 2 of 2
    • Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
    • Do not force the cover open. Re-soften the adhesive with an iOpener or hair dryer if the back cover does not come off or begins to warp.
    • On the photo opposite three corners have been released, with one corner remaining to be able to completely remove the glass.
    • Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
  4. Samsung Galaxy A8(2018) Back Cover Replacement: step 4, image 1 of 1
    • Unplug the fingerprint reader with tweezers.
  5. Samsung Galaxy A8(2018) Back Cover Replacement: step 5, image 1 of 1
    • Remove the back cover.
    • Prepare for reassembly by removing the remaining adhesive from the phone with a spudger. Clean the adhesive surfaces with isopropyl alcohol and a lint-free cloth.
To reassemble your device, follow the instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Jean pierre bourhis
305 Reputation
1 Guide authored
Leroy Merlin Member of Leroy Merlin
Community
36 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 107
All Time: 2,808
